What do these air flaps do?, And how important are they? |
JeffBowlsby |
Dec 15 2005, 01:51 PM
914 Wiring Harnesses Group: Members Posts: 8,558 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I bet most 914s don’t have these flaps anymore. These hinged flaps in the diagram are called ‘engine fan flaps’ or ‘non-return flaps’ in the parts manual. They close off the supply air duct path from the engine fan to the heat exchangers when the engine is off by gravity. They open up with the force of supply air to the heat exchangers when the engine is spinning, to circulate air through the HEs into the cabin, as assisted by the electric blower fan in the engine bay.
So the only thing I can figure is that after the car is hot and the engine is shut off, the flaps close to prevent hot air from entering the supply air fan plenum…but I can’t figure out why that’s important. Any ideas? Attached image(s) |
Bleyseng |
Dec 16 2005, 08:54 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
The upper cooling flaps should jam open if the cable breaks or the thermostat fails so there is no way it will overheat the engine. (IMG:http://www.914world.com/bbs2/html/emoticons/chair.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 06:29 AM |
