ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,980 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Specifically I am looking for rotational stiffness (ie. twist) of the trailing arm due to the tire contact patch resisting sideways sliding of the car. I'm only interested in forces greater than 1G during cornering.
I already know what happens but go ahead and take a guess. (IMG:style_emoticons/default/biggrin.gif) I'll post pictures of my test fixture shortly. |
ChrisFoley |
I have several more tests planned already.
1) measure a trailing arm with the standard box kit installed. 2) measure a trailing arm with my idea of a better stiffener. * 3) measure the fore/aft deflection of the arm by applying the load 90 degrees to what I did for this test. This will simulate what happens under 1G of braking force. * My better stiffener will be very simple, lightweight, and will allow me to make a camber change to the trailing arm at the same time. (IMG:style_emoticons/default/smile.gif) I just need to make another fixture so I can weld it together with the correct geometry. (IMG:style_emoticons/default/welder.gif) |
