dmilzoff |
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 ![]() |
Am I getting too fanatical or is this a real problem?
On my 914-6, I have 911 brakes up front and original rear brakes. I found the right rear brake dragging (smoking!). After opeining the vent clearance and oiling the emergency brake linkage, I took the car out for a 4 mile ride. Rotor temperatures using a infrared temp probe was Left Front 145 deg. F. Right Front 150 Left Rear 180 Right Rear 225 Question 1: Shouldn't the front rotors be hotter? Should I remove the brake proportioning valve or replace it with a new one to correct this? Question 2: Is the right rear too hot for such a short ride? |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
Everybody seemed to forget that the fronts are vented and the rears are solid rotors. That would seem to explain why the fronts are running cooler.
-Ben M. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:02 PM |
