> trailing arm bushings, How to remove?
Qarl
post Aug 24 2003, 05:29 PM
Shriveled member
Okay... I spent the weekend disassembly the rear suspension.
Oh yeah, my suspension was all off the car.
F-ING CASTELATED NUTS!!!!! It took quite a few sessions with a propane torch and a high-torque impact wrench on max setting to remove each one.
It's real fun removing this nut without the car mounted to anything. The hub and axle just rotate away!!!
I ended up placing the hub (still mounted on the trailing arm with the axle attached into a vise on my bench). I tried removing it with a socket extension and 24" breaker bar. No such luck. The heat and impact wrench worked after many repeated attempts. My teeth are sore from clamping down.
Okay.. so now I just have to remove the hub and bearings. No problem.
What about the bushings? I plan on installing Muellers needle bearings in the rear, but I have no idea how to get the old stuff out.
Any advice?
vortrex
post Aug 24 2003, 09:44 PM
puncture through the rubber.
- Lo-Fi Version Time is now: 29th April 2025 - 06:08 PM
