ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,980 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Specifically I am looking for rotational stiffness (ie. twist) of the trailing arm due to the tire contact patch resisting sideways sliding of the car. I'm only interested in forces greater than 1G during cornering.
I already know what happens but go ahead and take a guess. (IMG:style_emoticons/default/biggrin.gif) I'll post pictures of my test fixture shortly. |
Thorshammer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 ![]() |
I have'nt seen this thread until this morning, but wanted to add some comments.
Chris and I started talking about this because som eof the info we have found for 914's seems at times to be untrue. People have done things for different reasons and many are not known. Such as The outer (stock) pick up point piece is extremely flexible, Chris has a stronger piece, I used it it works well. Why some people use a trailing arm stiffening kit and others do not. Here are the things we want to know: -How much does a standard trailing arm twist in degrees of deflection when we load it near max load that we might see with slick under racing conditions. . Only flaw I can see in Chris's methodology is maybe we have under or over estimated the load at the wheels. It also has a lever that would act upon the trailing arm, the Wheel. 11.75inches from the centerline. So we really need to make sure we've thought that through. -How much lateral deformation when a max cornering load is applied. Meaning doe the arm bend thowards the transmission when we load it and if so how much. -Where does it bend or Twist -How does a trailing arm that is stiffened using the typical weld on plates perform to the same tests. -Where can the arm be properly strengthend while adding minimal weight. Keeping in mind that some bending can be advantageous in gaining car "feel" at the limit. Same with Chassis twist, if its too stiff it looks good on paper but does not give the driver any feel and therefore be difficult to drive at the limit. These are the problems we (Chris) are trying to solve. Erik Madsen |
