> trailing arm bushings, How to remove?
Qarl
post Aug 24 2003, 05:29 PM
Shriveled member
Okay... I spent the weekend disassembly the rear suspension.
Oh yeah, my suspension was all off the car.
F-ING CASTELATED NUTS!!!!! It took quite a few sessions with a propane torch and a high-torque impact wrench on max setting to remove each one.
It's real fun removing this nut without the car mounted to anything. The hub and axle just rotate away!!!
I ended up placing the hub (still mounted on the trailing arm with the axle attached into a vise on my bench). I tried removing it with a socket extension and 24" breaker bar. No such luck. The heat and impact wrench worked after many repeated attempts. My teeth are sore from clamping down.
Okay.. so now I just have to remove the hub and bearings. No problem.
What about the bushings? I plan on installing Muellers needle bearings in the rear, but I have no idea how to get the old stuff out.
Any advice?
Brad Roberts
post Aug 25 2003, 09:16 AM
914 Freak!
FYI:
Protect the threads on the shaft (if you plan to keep the shafts) with a steel 911 lug nut when your smacking the end with a hammer.
I know Karl wont be reusing his shafts.... but I thought everyone should know... dont F-up the threads. You will hate life.
Which is why I dont hammer on the shafts...
B
- Lo-Fi Version Time is now: 29th April 2025 - 06:31 PM
