Measuring Carb air draw, Weird Reaction at #1 |
Allan |
Dec 18 2005, 01:10 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
While measuring the air flow on my carbs the motor would want to die when we put the meter on the stack feeding the #1 cylinder. All the others were fine.
Any ideas??? |
Dr. Roger |
Dec 18 2005, 01:53 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
sounds like a vacuum leak at the vacuum access point.
the only reason i know to have air running past the butterfly is to tone down a radical cam. radical cam = less vacuum. less vacuum =less air/fuel at idle. some guys drill a very small hole or two in their butterflies. i do not suggest you do this. most likely the butterflies are worn and metering ways gummed up a bit. are they old/worn carbs? my last carb was setup that way buy it was old and needed a rebuild. i got a new weber and she runs like a top. upon furthur inspection ans speaking with the PO, i found air and fuel metering was fine but the butterflies were not sealing very well and PO has jetted up on the transition circuit trying to get it to idle right. |
Lo-Fi Version | Time is now: 28th June 2024 - 12:47 AM |
