914_6conv |
Newbie ![]() Group: Members Posts: 7 Joined: 25-August 03 From: sorel-tracy, quebec Member No.: 1,075 ![]() |
Hi, new to the list but not to 914s. My problem is that whenever i try to restart the engine after a short stop, lets say a fuel fill-up, it just doesnt. It cranks, but does not fire. After a while, 5-10 minutes, it does. No problem on cold start, it fires right away. I suspect bad coil, misbehaves when hot. But once started, it runs fine. any clue? My set up: Blue coil, Permatune, Pressure regulator, webers on a 2.2E engine with S-cams. Thanks to all.
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
I had this problem, was very confusing initially because if you played
around with ignition things, it would start working, but only because time had let it cool down. The problem was the Permatune. (IMG:style_emoticons/default/icon8.gif) I don't know how, but my failure mode was no spark when car (permatune unit) was hot, after you shut it off. It didn't just die while driving for some reason. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:37 AM |
