> 2.5 shor stroke engine, my plans
michel richard
post Dec 20 2005, 07:21 PM
So here's what I'm doing for the engine as part of my "GT style" conversion. First and foremost, I figure that an engine in a GT style car has to be rev-happy.
So, here's what I'm putting together, with the help of my trusty wrench, Ron Green of Campbell Gararge in Montreal:
Short stoke 2.5 Porsche engine:
1) Used 7R engine case, align bored, Timeserted, shuffle pinned
2) 90 mm JE pistons, 10.5 compression ratio
3) 90 mm replated Nickasil cylinders, sourced from EBS
4) Standard piston ring set
5) 66 mm counterweighted crankshaft
6) GE 80 camshafts
7) EBS racing valve springs
8) EBS valve spring retainer set for above
9) 2.0 connecting rods
10) ARP rod bolts and nuts for above
11) twin plugged heads
12) Electromotive HPV twin ignition
13) Turbo lower valve covers
14) front mounted ol cooler with "GT Style" installation
15) new bearings and gaskets all around
16) miscelaneous engine parts, stock.
I still need to figure out what to do with the port sizes in the head. The target is to have a 8,000 rpm redline, and 250 hp, although the redline is more important than the hp to me.
So that's the plan. I pulled the trigger on the hard parts above today. ( I already have the crank and the miscelaneous parts).
Induction is going to be 40 mm PMO carbs, jetting to be determined.
I'll post to this thread as progress is mad on the engine.
Michel Richard
brant
post Dec 22 2005, 12:07 AM
I'm not as knowledgeable as I'd like to be.
but what Tim is saying makes A lot of sense.
if your going to have 15K+ into your motor, its at least thinking over!
brant
michel richard   2.5 shor stroke engine   Dec 20 2005, 07:21 PM
d914   most of the race 2.5 go with 46's one locally ...   Dec 20 2005, 07:34 PM
michel richard   Greg, I hear you. To me, this is mostly a street...   Dec 20 2005, 07:46 PM
d914   I would check them out, little to prove my point b...   Dec 20 2005, 07:51 PM
kevgentile   8,000 is to high for a mag case. you will walk the...   Dec 20 2005, 08:27 PM
d914   agreed, but mine was in an old AL case, had red li...   Dec 20 2005, 08:39 PM
campbellcj   Sounds fun. If I ever build a new motor for my cu...   Dec 20 2005, 09:41 PM
Brett W   I agree with Greg, I would look at a bigger carb a...   Dec 20 2005, 11:08 PM
trekkor   I love the sound of the high revs, too. I keep my...   Dec 21 2005, 12:41 AM
fiid   <...   Dec 21 2005, 12:43 AM
messix   i'm not that experienced with porsche engines,...   Dec 21 2005, 01:18 AM
Brett W   http://www.914world.com/bbs2/h...   Dec 21 2005, 09:07 AM
TimT   Id shy away from using the 2.0 rods. They are the ...   Dec 21 2005, 09:23 AM
Brett W   How long are the stock 2.0 rods? What kind of rod...   Dec 21 2005, 09:31 AM
Mark Henry   For the price of those PMO's I'll get you ...   Dec 21 2005, 12:06 PM
michel richard   OK, Thanks for the collective wisdom. I'll c...   Dec 21 2005, 01:39 PM
Mark Henry   I'd have to check it out...but I know a guy wh...   Dec 21 2005, 02:37 PM
Brett W   I know Mark and some others like the SDS system, b...   Dec 21 2005, 02:44 PM
Mark Henry   Brett...Have you used an SDS? What do you mean "t...   Dec 21 2005, 03:11 PM
michel richard   Mark, Because I have the carbs, I would like star...   Dec 21 2005, 04:16 PM
brant   I know when Henry Schmidt put my 67S 2.0 together,...   Dec 21 2005, 05:43 PM
TimT   Ill mention the connecting rods again.. Porsche re...   Dec 21 2005, 09:33 PM
messix   rod length brings up alot of issues, longer rod to...   Dec 21 2005, 10:42 PM
Brett W   The SDS can't be setup to run in sequential in...   Dec 21 2005, 11:23 PM
brant   I'm not as knowledgeable as I'd like to be...   Dec 22 2005, 12:07 AM
Brett W   Sorry for the thread hi-jack. Tim and Brant are r...   Dec 22 2005, 12:19 AM
michel richard   Gentlemen, The reason for going to 2.0 rods is th...   Dec 22 2005, 08:46 AM
carr914   Michel, I'm in awe of the progress you have ma...   Dec 22 2005, 09:22 AM
michel richard   T. Thank you for your kind words. Peak hp arou...   Dec 22 2005, 09:51 AM
michel richard   T, And what hp figures did you get ? M   Dec 22 2005, 09:52 AM
michel richard   T, You mention jetting, which seems to mean that ...   Dec 22 2005, 09:55 AM
d914   2 liter rods 2.7 heads ports where larger specialt...   Dec 22 2005, 10:30 AM
Mark Henry   <...   Dec 22 2005, 01:01 PM
TimT   http://www.914world.com/bbs2...   Dec 22 2005, 01:43 PM
Mark Henry   TimT Shut-up...Shut-up, Shut-up, Shut-up! I...   Dec 22 2005, 01:52 PM
TimT   Im just sitting on the sidelines eating some popco...   Dec 22 2005, 01:55 PM
Mark Henry   That's OK...your system is also batch fired......   Dec 22 2005, 01:59 PM
trekkor   Let me drop this little "bomb" http...   Dec 22 2005, 02:14 PM
TimT   Actually the Haltech E11v2 can be set up for full ...   Dec 22 2005, 02:14 PM
Brett W     Dec 22 2005, 03:04 PM
TimT   http://www.914world.com/bbs2/h...   Dec 22 2005, 03:52 PM
carr914   Michel, 7R case 2.2 rods 2.7 heads JE custom desi...   Dec 22 2005, 06:12 PM
michel richard   T, do you have you rport size ? your jetting ? Wh...   Dec 22 2005, 07:05 PM
trekkor   Yes, that sounds like quite the mill.
- Lo-Fi Version Time is now: 26th April 2025 - 03:11 AM
