Hot starting problems.... on a 914/6 |
914_6conv |
Aug 25 2003, 05:53 PM
Newbie Group: Members Posts: 7 Joined: 25-August 03 From: sorel-tracy, quebec Member No.: 1,075 |
Hi, new to the list but not to 914s. My problem is that whenever i try to restart the engine after a short stop, lets say a fuel fill-up, it just doesnt. It cranks, but does not fire. After a while, 5-10 minutes, it does. No problem on cold start, it fires right away. I suspect bad coil, misbehaves when hot. But once started, it runs fine. any clue? My set up: Blue coil, Permatune, Pressure regulator, webers on a 2.2E engine with S-cams. Thanks to all.
rhodyguy |
Aug 26 2003, 07:28 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
he says it cranks hot or cold.occasionally my 4 with carbs starts a little ruf on a HOT day after restart and a short sit. could this be the fuel heating up in the lines and the carb bowls?
kevin |
Lo-Fi Version | Time is now: 25th September 2024 - 10:51 PM |
