michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
So here's what I'm doing for the engine as part of my "GT style" conversion. First and foremost, I figure that an engine in a GT style car has to be rev-happy.
So, here's what I'm putting together, with the help of my trusty wrench, Ron Green of Campbell Gararge in Montreal: Short stoke 2.5 Porsche engine: 1) Used 7R engine case, align bored, Timeserted, shuffle pinned 2) 90 mm JE pistons, 10.5 compression ratio 3) 90 mm replated Nickasil cylinders, sourced from EBS 4) Standard piston ring set 5) 66 mm counterweighted crankshaft 6) GE 80 camshafts 7) EBS racing valve springs 8) EBS valve spring retainer set for above 9) 2.0 connecting rods 10) ARP rod bolts and nuts for above 11) twin plugged heads 12) Electromotive HPV twin ignition 13) Turbo lower valve covers 14) front mounted ol cooler with "GT Style" installation 15) new bearings and gaskets all around 16) miscelaneous engine parts, stock. I still need to figure out what to do with the port sizes in the head. The target is to have a 8,000 rpm redline, and 250 hp, although the redline is more important than the hp to me. So that's the plan. I pulled the trigger on the hard parts above today. ( I already have the crank and the miscelaneous parts). Induction is going to be 40 mm PMO carbs, jetting to be determined. I'll post to this thread as progress is mad on the engine. Michel Richard |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
TimT
Shut-up...Shut-up, Shut-up, Shut-up! I'm on a rant! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Lo-Fi Version | Time is now: 26th April 2025 - 02:54 AM |
