| michel richard |
Dec 20 2005, 07:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
So here's what I'm doing for the engine as part of my "GT style" conversion. First and foremost, I figure that an engine in a GT style car has to be rev-happy.
So, here's what I'm putting together, with the help of my trusty wrench, Ron Green of Campbell Gararge in Montreal: Short stoke 2.5 Porsche engine: 1) Used 7R engine case, align bored, Timeserted, shuffle pinned 2) 90 mm JE pistons, 10.5 compression ratio 3) 90 mm replated Nickasil cylinders, sourced from EBS 4) Standard piston ring set 5) 66 mm counterweighted crankshaft 6) GE 80 camshafts 7) EBS racing valve springs 8) EBS valve spring retainer set for above 9) 2.0 connecting rods 10) ARP rod bolts and nuts for above 11) twin plugged heads 12) Electromotive HPV twin ignition 13) Turbo lower valve covers 14) front mounted ol cooler with "GT Style" installation 15) new bearings and gaskets all around 16) miscelaneous engine parts, stock. I still need to figure out what to do with the port sizes in the head. The target is to have a 8,000 rpm redline, and 250 hp, although the redline is more important than the hp to me. So that's the plan. I pulled the trigger on the hard parts above today. ( I already have the crank and the miscelaneous parts). Induction is going to be 40 mm PMO carbs, jetting to be determined. I'll post to this thread as progress is mad on the engine. Michel Richard |
| Trekkor |
Dec 22 2005, 02:14 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Let me drop this little "bomb" (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
When I had an understanding of "how to" sync my triple Webers, it was less than an hour. Haven't touched the settings since last January. Sure, jet cleaning, air cleaner washes... I was just telling somebody a couple of days ago how simple it is. You could turn in all the idles and air corrections on my carbs and I would have it back to where it is now in 15 minutes, I promise you that. If and when I ever take the car to a dyno, *maybe* there are gains to be made. Carbs are not evil. Sure they rough start when cold, but I hope none you go romp on your motors when they're cold. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) 7300 rpm revving 2.0 SIX on carbs...Out. KT |
michel richard 2.5 shor stroke engine Dec 20 2005, 07:21 PM
d914 most of the race 2.5 go with 46's one locally ... Dec 20 2005, 07:34 PM
michel richard Greg,
I hear you. To me, this is mostly a street... Dec 20 2005, 07:46 PM
d914 I would check them out, little to prove my point b... Dec 20 2005, 07:51 PM
kevgentile 8,000 is to high for a mag case. you will walk the... Dec 20 2005, 08:27 PM
d914 agreed, but mine was in an old AL case, had red li... Dec 20 2005, 08:39 PM
campbellcj Sounds fun. If I ever build a new motor for my cu... Dec 20 2005, 09:41 PM
Brett W I agree with Greg, I would look at a bigger carb a... Dec 20 2005, 11:08 PM
trekkor I love the sound of the high revs, too.
I keep my... Dec 21 2005, 12:41 AM
fiid <... Dec 21 2005, 12:43 AM
messix i'm not that experienced with porsche engines,... Dec 21 2005, 01:18 AM
Brett W http://www.914world.com/bbs2/h... Dec 21 2005, 09:07 AM
TimT Id shy away from using the 2.0 rods. They are the ... Dec 21 2005, 09:23 AM
Brett W How long are the stock 2.0 rods? What kind of rod... Dec 21 2005, 09:31 AM
Mark Henry For the price of those PMO's I'll get you ... Dec 21 2005, 12:06 PM
michel richard OK,
Thanks for the collective wisdom. I'll c... Dec 21 2005, 01:39 PM
Mark Henry I'd have to check it out...but I know a guy wh... Dec 21 2005, 02:37 PM
Brett W I know Mark and some others like the SDS system, b... Dec 21 2005, 02:44 PM
Mark Henry Brett...Have you used an SDS?
What do you mean "t... Dec 21 2005, 03:11 PM
michel richard Mark,
Because I have the carbs, I would like star... Dec 21 2005, 04:16 PM
brant I know when Henry Schmidt put my 67S 2.0 together,... Dec 21 2005, 05:43 PM
TimT Ill mention the connecting rods again.. Porsche re... Dec 21 2005, 09:33 PM
messix rod length brings up alot of issues, longer rod to... Dec 21 2005, 10:42 PM
Brett W The SDS can't be setup to run in sequential in... Dec 21 2005, 11:23 PM
brant I'm not as knowledgeable as I'd like to be... Dec 22 2005, 12:07 AM
Brett W Sorry for the thread hi-jack. Tim and Brant are r... Dec 22 2005, 12:19 AM
michel richard Gentlemen,
The reason for going to 2.0 rods is th... Dec 22 2005, 08:46 AM
carr914 Michel, I'm in awe of the progress you have ma... Dec 22 2005, 09:22 AM
michel richard T.
Thank you for your kind words.
Peak hp arou... Dec 22 2005, 09:51 AM
michel richard T,
And what hp figures did you get ?
M Dec 22 2005, 09:52 AM
michel richard T,
You mention jetting, which seems to mean that ... Dec 22 2005, 09:55 AM
d914 2 liter rods
2.7 heads
ports where larger
specialt... Dec 22 2005, 10:30 AM
Mark Henry <... Dec 22 2005, 01:01 PM
TimT http://www.914world.com/bbs2... Dec 22 2005, 01:43 PM
Mark Henry TimT
Shut-up...Shut-up, Shut-up, Shut-up!
I... Dec 22 2005, 01:52 PM
TimT Im just sitting on the sidelines eating some popco... Dec 22 2005, 01:55 PM
Mark Henry That's OK...your system is also batch fired...... Dec 22 2005, 01:59 PM
TimT Actually the Haltech E11v2 can be set up for full ... Dec 22 2005, 02:14 PM
Brett W ![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:25 AM |
