bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay, so I know that L-jet uses the point pulses to fire injectors...my main relay is working, so what connections do i need at the coil?
i already have the tach wire, the point wire at the neg and nothing at the positive.... but i have a brown wire and two black wires joined to one both sets of wires having 12VDC on them....what gives? b |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Your L-Jet is from a 1974.
The double relay has a black wire that goes to pin (15) on the coil. The ECU harness pin (1) goes to pin (1) on the coil {also supposed to be black} The 'other' wires terminating at the coil are: pin (1) Green to points pin (1) Black/Purple to Tachometer pin (15) Black (+12V from fuse S9) No brown wires should terminate at the coil. I believe you may have something wired incorrectly. Do you have the wiring diagrams? |
