bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay, so I know that L-jet uses the point pulses to fire injectors...my main relay is working, so what connections do i need at the coil?
i already have the tach wire, the point wire at the neg and nothing at the positive.... but i have a brown wire and two black wires joined to one both sets of wires having 12VDC on them....what gives? b |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
ok, good, you have spark.
now key on. open up the aircleaner box...or remove it from the throttle body (its easier that way) slide your hand in there and feel the flapper valve... with key on, and radio off....move flapper valve and listen for the fuel pump. Do you here it? If not you are not getting power to the relays...they feed power to the fuel pump. tell me those results. Rich |
