> L-jet wiring at coil
bd1308
post Dec 28 2005, 10:36 PM
Sir Post-a-lot
okay, so I know that L-jet uses the point pulses to fire injectors...my main relay is working, so what connections do i need at the coil?
i already have the tach wire, the point wire at the neg and nothing at the positive....
but i have a brown wire and two black wires joined to one both sets of wires having 12VDC on them....what gives?
b
John
post Dec 29 2005, 07:42 PM
member? what's a member?
Excellent! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Now you must make sure ALL vacuum leaks are TOTALLY sealed up (even a leaky or loose oil filler cap can make them not run well).
Also you need to set timing and dwell fairly accurately. It will be best when you get all the FI components installed like the aux air regulator and the thermo time switch.
If you need more free advice, I'm full of it! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
bd1308   L-jet wiring at coil   Dec 28 2005, 10:36 PM
bd1308   and i also have a white FI wire coming way off and...   Dec 28 2005, 10:55 PM
Jeff Bowlsby   Britt- There is a series of 3 L-Jet diagrams unde...   Dec 28 2005, 11:21 PM
JOHNMAN   Your L-Jet is from a 1974. The double relay has a...   Dec 28 2005, 11:23 PM
bd1308   let's do this step by step then: A)where does...   Dec 28 2005, 11:30 PM
lapuwali   The white wire may go to the AAR. It's just s...   Dec 28 2005, 11:35 PM
bd1308   the yellow wire is regular sized wire...this harne...   Dec 28 2005, 11:39 PM
Jeff Bowlsby   L-Jet harnesses are completely different than D-Je...   Dec 28 2005, 11:51 PM
bd1308   mine is the 74 without the altitude compensator. ...   Dec 28 2005, 11:58 PM
JOHNMAN   (E) Red from the Dual relay -> To Batttery +12V (...   Dec 29 2005, 12:03 AM
bd1308   http://www.914world.com/bbs2/ht...   Dec 29 2005, 08:55 AM
bd1308   oh and Jeff thanks for the figures on your site, I...   Dec 29 2005, 09:00 AM
Flat VW   http://www.914world.com/bbs...   Dec 29 2005, 09:06 AM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 09:08 AM
r_towle   Britt, What do you need. We have a 74 ljet all don...   Dec 29 2005, 09:41 AM
bd1308   i am like almost there..... im SO close.... I th...   Dec 29 2005, 09:48 AM
r_towle   Britt, neg coil green wire to points white wire to...   Dec 29 2005, 10:18 AM
bd1308   yeah but that wierd white or brown wire (from dual...   Dec 29 2005, 10:21 AM
r_towle   I have the big dual relay thing, and the smaller d...   Dec 29 2005, 10:24 AM
r_towle   tell me , when you lay the harness down where it i...   Dec 29 2005, 10:26 AM
bd1308   its not on the FI harness but off of the dual rela...   Dec 29 2005, 10:27 AM
Aaron Cox   pictures can help us help you... help us....help ...   Dec 29 2005, 10:38 AM
r_towle   ok, the entire wiring harness that enables your FI...   Dec 29 2005, 10:43 AM
Jeff Bowlsby   Does the yellow wire have a 1/4" wide long-blade m...   Dec 29 2005, 10:59 AM
bd1308   here's a pic. I dont even have spark now, and ...   Dec 29 2005, 11:10 AM
r_towle   start simple. Do you have power to the coil, key o...   Dec 29 2005, 11:20 AM
bd1308   i do have power to the coil, 12V at one end and th...   Dec 29 2005, 11:22 AM
r_towle   get a test light. I believe you may have power to...   Dec 29 2005, 11:34 AM
bd1308   i have two sets of everything, two coils and two d...   Dec 29 2005, 11:45 AM
r_towle   pull a plug wire, connect it to an old plug, groun...   Dec 29 2005, 11:50 AM
bd1308   okay i pulled a plug and voila! i have spark.....   Dec 29 2005, 12:05 PM
r_towle   so, with a test light. mount one side of test lig...   Dec 29 2005, 12:10 PM
bd1308   and does somebody have a relay board pic of a L-je...   Dec 29 2005, 12:11 PM
bd1308   teh spark was real yellow.... but i have spark. ...   Dec 29 2005, 12:13 PM
r_towle   ok, good, you have spark. now key on. open up the...   Dec 29 2005, 12:13 PM
bd1308   i had my fuel pump re-wired to the front trunk and...   Dec 29 2005, 12:18 PM
JOHNMAN   The relay boards are the same d-jet and l-jet. I ...   Dec 29 2005, 12:21 PM
bd1308   there was, I looked at it yesterday. anyway, with...   Dec 29 2005, 12:23 PM
r_towle   you will need to have the correct fuel pump instal...   Dec 29 2005, 12:25 PM
bd1308   the pump is already primed. heard the bubbles and ...   Dec 29 2005, 12:30 PM
r_towle   aar has vacuum hoses to it and the intake... all ...   Dec 29 2005, 12:33 PM
bd1308   guess i need to go to FLAPS. b   Dec 29 2005, 12:34 PM
bd1308   but okay, whats the deal with no power at the fuel...   Dec 29 2005, 12:35 PM
JOHNMAN   You could jumper a ground to make the fuel pump ru...   Dec 29 2005, 12:41 PM
r_towle   The deal is that you changed the wiring to the fue...   Dec 29 2005, 12:42 PM
bd1308   well the issue here isnt that my fuel pump doesnt ...   Dec 29 2005, 12:44 PM
r_towle   hang on for a sec.... that is the djet relay setu...   Dec 29 2005, 12:46 PM
bd1308   HUH? http://www.914world.com/bbs2/h...   Dec 29 2005, 12:49 PM
r_towle   no the relay board is the same. The LJET uses onl...   Dec 29 2005, 12:51 PM
JOHNMAN   B The relay boards are the same D-Jet or L-Jet. ...   Dec 29 2005, 12:56 PM
bd1308   at this present moment, no. I have the Haynes manu...   Dec 29 2005, 12:59 PM
bd1308   following this troubleshooting guide for L-jet mot...   Dec 29 2005, 01:10 PM
lapuwali   You should be able to test the relays themselves. ...   Dec 29 2005, 01:15 PM
r_towle   dont make it so complicated in your mind. to make...   Dec 29 2005, 01:22 PM
Mueller     Dec 29 2005, 01:27 PM
bd1308   now the battery is dead. this day is good. b   Dec 29 2005, 01:30 PM
jim912928   Easy way to check if your injectors are opening/cl...   Dec 29 2005, 01:39 PM
bd1308   uh, houston, no power to the injectors. b   Dec 29 2005, 01:48 PM
Mueller     Dec 29 2005, 01:59 PM
Mueller   for testing ONLY...... you could run a 12vdc + to...   Dec 29 2005, 02:02 PM
bd1308   EDIT! no power to resistor pack. now what? i...   Dec 29 2005, 02:03 PM
Mueller     Dec 29 2005, 02:04 PM
bd1308   <...   Dec 29 2005, 02:09 PM
JOHNMAN   Does the relay click when you turn the key on? Is...   Dec 29 2005, 02:13 PM
Mueller   is the AFM open? when the AFM opens, a microswitc...   Dec 29 2005, 02:14 PM
bd1308   if its the brown wire, then yes its grounded. I ju...   Dec 29 2005, 02:15 PM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 02:22 PM
bd1308   I open the AFM and nada...nothin. Might as well b...   Dec 29 2005, 02:22 PM
JOHNMAN   B, Have you opened the PDF of the wiring diagram ...   Dec 29 2005, 02:27 PM
Mueller     Dec 29 2005, 02:30 PM
bd1308   okay...let me back up for a sec. I plugged the yel...   Dec 29 2005, 02:31 PM
bd1308   <...   Dec 29 2005, 02:34 PM
JOHNMAN     Dec 29 2005, 02:41 PM
bd1308   i had it correct via the haynes manual. I dunno. ...   Dec 29 2005, 02:44 PM
jim912928   don't be discouraged...once you get the kinks ...   Dec 29 2005, 02:49 PM
JOHNMAN   Do you get power at the AFM (pin 39) if you manual...   Dec 29 2005, 02:51 PM
bd1308   im trying not to...... it helps having people tha...   Dec 29 2005, 02:54 PM
bd1308   okay i think that if my battery wasnt borderline d...   Dec 29 2005, 03:02 PM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 03:29 PM
JOHNMAN   You can get the fuel injectors to click when manua...   Dec 29 2005, 04:03 PM
bd1308   yep....click click click...it made me happy it di...   Dec 29 2005, 04:04 PM
JOHNMAN   I suppose that we should start right there. They ...   Dec 29 2005, 04:18 PM
bd1308   it checks out. ground is on 85 and power is on 86c...   Dec 29 2005, 04:30 PM
bd1308   its off to be recharge, i'll update when it ge...   Dec 29 2005, 05:06 PM
JOHNMAN   I'll try to help any way I can. I know that s...   Dec 29 2005, 06:09 PM
bd1308   okay... it fires. wont idle and doesnt like to p...   Dec 29 2005, 07:33 PM
JOHNMAN   Excellent! http://www.914...   Dec 29 2005, 07:42 PM
bd1308   got a Q for the peanut gallery.... what's up ...   Dec 29 2005, 07:53 PM
r_towle   Way to go Britt, You will love a solid well tune...   Dec 29 2005, 07:59 PM
JOHNMAN   I don't know if it would run too rich. It is ...   Dec 29 2005, 08:03 PM
bd1308   im working on it... the big step here is to get t...   Dec 29 2005, 08:03 PM
bd1308   maybe i have the fuel pressure regulator backwards...   Dec 29 2005, 08:06 PM
grasshopper   sorry...slight hijack here... but i just bought a ...   Dec 29 2005, 08:08 PM
bd1308   mine was all in the wiring...three hours ago i was...   Dec 29 2005, 08:12 PM
JOHNMAN   grasshopper, You may want to start a new thread, ...   Dec 29 2005, 08:44 PM
bd1308   another thread would be a excellent idea...   Dec 29 2005, 08:49 PM
rdauenhauer   Britt WOW http://www.914world.com/...   Dec 29 2005, 09:12 PM
bd1308   well it seems like its stubling and rough running,...   Dec 29 2005, 09:53 PM
bd1308   rich, thanks buddy. I have the plenum in a box for...   Dec 29 2005, 09:54 PM
JOHNMAN   Have you double checked that the injector groups a...   Dec 29 2005, 10:34 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 26th June 2024 - 09:13 AM
