d7n7master |
Gary# ![]() ![]() ![]() Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 ![]() |
Hi All,
I'm in the process of re-installing my engine in my '73. Many of the nuts & bolts I removed to drop the engine have seen better days. Is there a hardware "kit" that I can buy that replaces all of the bolts, nuts, & washers I need to re-install the engine??? I especially need the bolts that attach the motor mount brkts to the engine & the bolts & nuts that attach the engine mount. Thanks, Here's a pic of my rebuilt 2165 "almost" is ready to install. Attached image(s) ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I believe that nuts, in general, are all the same grade and are available in various finishes if that matters. On the other hand, the bolts DO come in many grades according to the job they are expected to do. The grade is marked on the head, and replacements should always be the same grade. The big trick is to know where each bolt came from.
Lo-Fi Version | Time is now: 29th June 2024 - 02:04 AM |
