> Mueller bearing install and 5 lug conversion, The time has come
Leo Imperial
post Nov 17 2005, 01:48 PM
Do you have to use so many cuss words?
So I won these parts at the WWC05'. I didn't even know at first what they were, but it didn't take long for the flock to move in and start making offers. Well I decided to do some research and I started collecting parts.
The front end has all been removed including the steering assembly. Turbo tierods will be part of the rebuild. The current swaybar is a 22mm adjustable upfront and will remain. I am keeping the stock 18mm torsion bars and a-arms. Everything else is being refreshed or replaced.
When the front is done the rear will be converted to 5 lug and a rear swaybar will be installed. Also if they can be obtained a set of Mueller bearings.
So here is the first set of pictures and questions fo Mike.
Leo Imperial
post Dec 31 2005, 08:29 PM
Front completed and the rear now in progress.
Leo Imperial   Mueller bearing install and 5 lug conversion   Nov 17 2005, 01:48 PM
Leo Imperial   So here is the test fit in pictures.   Nov 17 2005, 01:51 PM
Leo Imperial   Perfect fit!   Nov 17 2005, 01:52 PM
Leo Imperial   I mean this is a perfect fit.   Nov 17 2005, 01:53 PM
Leo Imperial   Washer   Nov 17 2005, 01:54 PM
Leo Imperial   Roller   Nov 17 2005, 01:55 PM
Leo Imperial   Washer   Nov 17 2005, 01:55 PM
Leo Imperial   The bearing   Nov 17 2005, 01:57 PM
Leo Imperial   O-ring   Nov 17 2005, 01:57 PM
Leo Imperial   And the front mount.   Nov 17 2005, 01:58 PM
Leo Imperial   Now to grease it all and do the actuall install. A...   Nov 17 2005, 02:00 PM
Mueller   Look'n good...make sure you lube the living da...   Nov 17 2005, 02:01 PM
Leo Imperial   Is this the type of grease you would use or should...   Nov 17 2005, 02:03 PM
maf914   I'm just a casual observer of the various bear...   Nov 17 2005, 02:19 PM
Leo Imperial   That was what I had read also. This stuff makes th...   Nov 17 2005, 02:25 PM
Mueller     Nov 17 2005, 02:27 PM
airsix   Does the sleeve that the large bearing runs on hav...   Nov 17 2005, 02:39 PM
McMark   http://www.914world.com/bbs2/h...   Nov 17 2005, 02:39 PM
Aaron Cox     Nov 17 2005, 02:40 PM
Leo Imperial   I have alredy done the install with this shit. Sho...   Nov 18 2005, 02:18 AM
rdauenhauer   Leo, Im sorta at the same point with my install. T...   Nov 18 2005, 04:31 PM
Mueller   as long as the sleeve was not too loose, as in it ...   Nov 18 2005, 04:43 PM
Leo Imperial   I got lazy withposting, so here is an update of pi...   Dec 31 2005, 08:25 PM
Leo Imperial   With correct boots   Dec 31 2005, 08:26 PM
Leo Imperial   Full assembly   Dec 31 2005, 08:27 PM
Leo Imperial   Front completed and the rear now in progress.   Dec 31 2005, 08:29 PM
Travis Neff   Looking good Leo. The all black cookies and stanc...   Dec 31 2005, 09:09 PM
- Lo-Fi Version Time is now: 29th April 2025 - 09:21 PM
