REMOVING JACK POSTS/PLATES, suggestions??? |
marks914 |
Dec 31 2005, 12:53 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I am currently installing my new set of B/M longitudinal clamshells. Any suggestions on removing the jack post/plates? I have the pass side done, I had to do some patching so I was not too careful in their removal. The driver side is solid, so I would like to remove it surgically. I have drilled out the spot welds I can reach, started prying and came in for lunch. I will post some pics of the progress this week
Thanks Mark |
marks914 |
Jan 1 2006, 02:12 PM
That's all the plug welds you can get, the holes are on the ribs of the long, the farther down you go, the poorer the gap. The lower section is also welded onto the drop flange. and the upper to the sill step plate. Its 3/32 thick, 38 lbs Mark I will snap a closeup of the rear part later. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:29 PM |
