Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
Hey guys and gals,
I'm setting my car up for street/racing use and i'm not sure about the spring rates and sway bar combo's on the rear. andyrew, i think, has 180lb springs and no swaybar. he gets around the AX track pretty well. but isn't 180 a bit stiff for street or is it OK with the added V8 weight? i know going too spring stiff will make streetability low. keeping stock springs but going large on a sway bar will keep her flat on the ground and retain some spring for streets. i was thinking of installing adjustable perchs to maintain ride height and keeping stock springs. then getting a rear sway bar and calling it good. thoughts? roger |
nine14cats |
Bill Pickering -- 914-6 GT aka....Leeloo ![]() ![]() ![]() ![]() Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None ![]() |
Hi Roger,
FWIW, Renegade recommends 21mm T-Bars and 200lbs rear springs, although that sounds like push to me. I have a set of the 200lbs RH springs for JLO when I finish the conversion, but I also have 180's if I think its too stiff. Rod Simpson likes 165 progressives for street and 180's for a dual purpose car (street/AX). Just a data point for you. Thanks, Bill P. |
Lo-Fi Version | Time is now: 26th June 2024 - 10:36 AM |
