Steering wheel wobble, How are bearings adjusted |
billd |
Jan 2 2006, 12:50 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
My steering wheel just developed a significant wobble. It moves several degrees left/right and up/down. The bolt holding the wheel to the splines is tight. The splined shaft itself is moving. I suspect that the bearings that hold the steering shaft have loosened up. Does anyone know the procedure for tightening them?
Dr Evil |
Jan 2 2006, 05:48 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Here is a pic of the typical 4cyl steering column as viewed from the bottom. This is the unit removed without the steering wheel. You can easily notice the four bolt holes in the gold colored part where you would find the allen head bolts that hold this assembly underneath the dash. These would be a good place to check first for loose bolts.
Attached image(s) |
Lo-Fi Version | Time is now: 25th June 2024 - 07:47 PM |
