Wanted: Opinions for best rear spring/sway combo, for V8 car. Rear setup. |
Dr. Roger |
Jan 2 2006, 01:00 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Hey guys and gals,
I'm setting my car up for street/racing use and i'm not sure about the spring rates and sway bar combo's on the rear. andyrew, i think, has 180lb springs and no swaybar. he gets around the AX track pretty well. but isn't 180 a bit stiff for street or is it OK with the added V8 weight? i know going too spring stiff will make streetability low. keeping stock springs but going large on a sway bar will keep her flat on the ground and retain some spring for streets. i was thinking of installing adjustable perchs to maintain ride height and keeping stock springs. then getting a rear sway bar and calling it good. thoughts? roger |
xitspd |
Jan 2 2006, 07:26 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
Roger,
Great job on the new calendar! I bought FIVE..... I drive my car 85% on the track and about 15% on the street. Following please find my specs: 400 pound springs are a little rough around town, but I sure like them on the track! Dan 1970 Factory 914-6, 3.6 993 Engine, 50MM PMO Webers, Electromotive Twin Plug Crank Fire, Aasse RSR Valve Springs with Titanium Retainers, WEB Euro Spec Grind Camshafts, PatrickMotorsports 1 3/4" Jet Coated Racing Headers with PatrickMotorsports Silencers, 901 Converted Side Shift Transmission with Factory 904 Main Shaft and Short Gears, Billet Aluminum Intermediate Plate, 225MM PatrickMotorsports Racing Clutch, PatrickMotorsports RSR Billet Aluminum Flywheel, Quaiffe LSD with Billet Side Plate, PatrickMotorsports Solid Transmission Mounts, Tilton Transmission Pump System with HD Fluidyne Oil Cooler, B&B 930 Front Mounted Engine Oil Cooler with Thermostat, 911 Front Suspension with Aluminum Cross Brace, Porsche Twin Turbo Brakes and Rotors Front and Rear, Pagid Racing Pads, 23MM Gun Drilled Front Torsion Bars, 930 Turbo Tie Rods, Charley Front Sway Bar, Porsche Factory Rear Sway Bar, RSR Threaded Front Bilstein Struts and Sport Valved Shocks, Eibach 400lb Rear Coilovers, Racers Group Adjustable Monoball Upper Strut Mounts, Poly-Graphite Suspension Bushings, 23MM Master Cylinder, 17 X 9 & 17 X 10 Kinesis Polished 3 Pc. Wheels, 914-6GT Chassis Stiffening Kit, 914-6GT Boxed Rear Suspension, RennShift Performance Shifter with Steve's Custom Fab Linkage, Full Chrome-Moly Cage, Porsche Factory GT Flares Butt Welded, 5Five5 Composite Front and Rear Hoods and Bumpers. Terazoom Quick Release Steering Hub. MOMO Prototipo Steering Wheel, MOMO Competizione Shift Knob, MOMO Composite Racing Seats, SPA Fire Suppression System, Patrick Motorsports 914 Fuel Safe Fuel Cell, Boman Graphics, built by Steve Aven Orange, CA |
Lo-Fi Version | Time is now: 26th June 2024 - 10:36 AM |
