> More clamshell pics, Here they are...
marks914
post Jan 2 2006, 01:47 PM
Thought I would start this thread over,
I am installing Brad Mayeur's Longitudinal clamshell kit. It should make the car MUCH stiffer.
Specs:
3/32 thick, plug and seam welded to the existing longs, and ties into the suspension console
Mark
marks914
post Jan 4 2006, 06:46 PM
QUOTE (Britain Smith @ Jan 4 2006, 01:41 PM)
IIRC, the actual strength of the longs are on the inside of the car. Why would one chose this kit instead of the one that installs under the carpet on the inside like Trekkor did.
-Britain
This kit ties the longs to the rear of the car, whereas the inner kit just strengthens the part between the door opening. The weakest point as far as I can tell is around the jack post. This is where the rear section joins the long. (and where cars sag)
horizontally opposed:
As to rusting from inside... The back side is painted, unlike the orignal. The car lasted 33 years, and this kit should last at least another 33. I don't think I will care when I'm in my 70s.
The whole point of the kit is to strengthen the weakest point of the car.
Yes, you do have to make sure the car is straight when you install the kit.
Here is a link on the Bird board with more info:
http://www.pelicanparts.com/techarticles/9...gitude_repl.htm
I will post a full article in the future with complete pics.
Mark
marks914   More clamshell pics   Jan 2 2006, 01:47 PM
marks914   Here you can see the section, very strong..   Jan 2 2006, 01:48 PM
marks914   Here is how the two pieces fit together.. I marked...   Jan 2 2006, 01:49 PM
marks914   You can trim around the box section if it is stron...   Jan 2 2006, 01:51 PM
marks914   On the driver side I had to cut out the boxed sect...   Jan 2 2006, 01:53 PM
marks914   Here is how the downstanding flange mates with the...   Jan 2 2006, 01:56 PM
marks914   This is why I started this project, pass side was ...   Jan 2 2006, 02:01 PM
dkos   <...   Jan 4 2006, 01:38 PM
groot   Cool.... just curious, where are you in the Motor ...   Jan 4 2006, 01:40 PM
marks914   dkos: Stitch welding is when you weld for a length...   Jan 4 2006, 02:21 PM
URY914   I would be careful that your car is sitting level ...   Jan 4 2006, 02:38 PM
dkos   <...   Jan 4 2006, 03:19 PM
Britain Smith   IIRC, the actual strength of the longs are on the ...   Jan 4 2006, 03:41 PM
horizontally-opposed   I like this idea a lot... BUT what about the rust...   Jan 4 2006, 03:44 PM
marks914   <...   Jan 4 2006, 07:13 PM
mikelsr     Jan 4 2006, 08:01 PM
groot   Mark, I missed MWC... I think it was a race weeke...   Jan 5 2006, 06:37 AM
dkos   <...   Jan 5 2006, 08:06 AM
Bleyseng   For the inner long, look at the Engman kit as it t...   Jan 5 2006, 09:33 AM
indydad   I'm doing the same thing right now. I got my s...   Jan 5 2006, 12:32 PM
marks914   It seems that the 914 that are available recently ...   Jan 5 2006, 02:20 PM
IanStott   I'm in the middle of a restoration and very in...   Jan 5 2006, 02:57 PM
marks914   <...   Jan 5 2006, 07:22 PM
marks914   Here's a pic with the tires: Mark   Jan 5 2006, 07:23 PM
IanStott   First you have a very nice looking car! If min...   Jan 6 2006, 07:54 AM
mudfoot76   <...   Jan 6 2006, 09:01 AM
marks914   <...   Jan 7 2006, 05:58 AM
Tom Perso   Nice car! I just had to add since I see my Mi...   Jan 7 2006, 07:17 AM
dkos   marks914, I usually prefer the stock look, but yo...   Jan 7 2006, 03:13 PM
wertygrog   hmmm where does one get this kit, and is it better...   Jan 10 2006, 03:33 PM
9146986   <...   Jan 21 2006, 11:31 PM
turbo914v8   The trick to getting your order processed from RD ...   Feb 5 2006, 09:21 AM
pek771   I started this thread: http://www.914world.com/bb...   Feb 5 2006, 09:38 AM
SpecialK   The PO of my '73 also installed Brad's sti...   Feb 5 2006, 10:15 AM
tat2dphreak   I'm thinking of putting this kit on as a rust-...   Feb 5 2006, 10:43 AM
SpecialK
- Lo-Fi Version Time is now: 30th January 2025 - 10:38 PM
