montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
My front end shakes when i drive, it happened after i towed it home from San Jose, Ca. (300 miles or so). Should I take it in to have it done or can I do it myself?
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
Does it shake when you're braking? In a corner? Or just when its rolling?
Here are some things to check: Check tire pressure. Try 35 lbs on each corner just to start. Put the car up on jackstands and shake all the wheels in and out to check for wheelbearings. There should be a little play on the wheels but not too much. The alignment could be off. Unless you're savvy with string and chalk, you'll have to take it in for that one. Wheels could be out of balance ie. a weight could have fallen off or you could have wheel damage. You'll have to take it in for that also. |
Lo-Fi Version | Time is now: 26th June 2024 - 11:14 AM |
