Monday, 24 February 2025
> More clamshell pics, Here they are...
marks914
post Jan 2 2006, 01:47 PM
Thought I would start this thread over,
I am installing Brad Mayeur's Longitudinal clamshell kit. It should make the car MUCH stiffer.
Specs:
3/32 thick, plug and seam welded to the existing longs, and ties into the suspension console
Mark
indydad
post Jan 5 2006, 12:32 PM
I'm doing the same thing right now. I got my stiffeners from Partwerk of Chicago. Actually had no problem from them, but that was several years ago.
I have Osphoed the inside of the longs twice, should be coated good. I plan to Por-15 the outer long after I do the same repair as you before the stiffener goes on and Por-15 both sides of the stiffener grinding off any welding spots.
I wonder if it would be a good idea to tack on both sides and then alternate welding from side to side to avoid warping. I am leaving the targa on and doors closed as much as possible. My door gap is good now.
Floor pans next. Does it ever end?
Ole dad in Indy
marks914   More clamshell pics   Jan 2 2006, 01:47 PM
marks914   Here you can see the section, very strong..   Jan 2 2006, 01:48 PM
marks914   Here is how the two pieces fit together.. I marked...   Jan 2 2006, 01:49 PM
marks914   You can trim around the box section if it is stron...   Jan 2 2006, 01:51 PM
marks914   On the driver side I had to cut out the boxed sect...   Jan 2 2006, 01:53 PM
marks914   Here is how the downstanding flange mates with the...   Jan 2 2006, 01:56 PM
marks914   This is why I started this project, pass side was ...   Jan 2 2006, 02:01 PM
dkos   <...   Jan 4 2006, 01:38 PM
groot   Cool.... just curious, where are you in the Motor ...   Jan 4 2006, 01:40 PM
marks914   dkos: Stitch welding is when you weld for a length...   Jan 4 2006, 02:21 PM
URY914   I would be careful that your car is sitting level ...   Jan 4 2006, 02:38 PM
dkos   <...   Jan 4 2006, 03:19 PM
Britain Smith   IIRC, the actual strength of the longs are on the ...   Jan 4 2006, 03:41 PM
horizontally-opposed   I like this idea a lot... BUT what about the rust...   Jan 4 2006, 03:44 PM
marks914   <...   Jan 4 2006, 07:13 PM
mikelsr     Jan 4 2006, 08:01 PM
groot   Mark, I missed MWC... I think it was a race weeke...   Jan 5 2006, 06:37 AM
dkos   <...   Jan 5 2006, 08:06 AM
Bleyseng   For the inner long, look at the Engman kit as it t...   Jan 5 2006, 09:33 AM
indydad   I'm doing the same thing right now. I got my s...   Jan 5 2006, 12:32 PM
marks914   It seems that the 914 that are available recently ...   Jan 5 2006, 02:20 PM
IanStott   I'm in the middle of a restoration and very in...   Jan 5 2006, 02:57 PM
marks914   <...   Jan 5 2006, 07:22 PM
marks914   Here's a pic with the tires: Mark   Jan 5 2006, 07:23 PM
IanStott   First you have a very nice looking car! If min...   Jan 6 2006, 07:54 AM
mudfoot76   <...   Jan 6 2006, 09:01 AM
marks914   <...   Jan 7 2006, 05:58 AM
Tom Perso   Nice car! I just had to add since I see my Mi...   Jan 7 2006, 07:17 AM
dkos   marks914, I usually prefer the stock look, but yo...   Jan 7 2006, 03:13 PM
wertygrog   hmmm where does one get this kit, and is it better...   Jan 10 2006, 03:33 PM
9146986   <...   Jan 21 2006, 11:31 PM
turbo914v8   The trick to getting your order processed from RD ...   Feb 5 2006, 09:21 AM
pek771   I started this thread: http://www.914world.com/bb...   Feb 5 2006, 09:38 AM
SpecialK   The PO of my '73 also installed Brad's sti...   Feb 5 2006, 10:15 AM
tat2dphreak   I'm thinking of putting this kit on as a rust-...   Feb 5 2006, 10:43 AM
SpecialK
- Lo-Fi Version Time is now: 24th February 2025 - 10:29 AM
