Engine Assembly Problems! |
TeamAxisRacing |
Jan 6 2006, 08:35 PM
Member Group: Members Posts: 107 Joined: 13-September 03 From: seattle, Wa Member No.: 1,153 |
hello i was wondering if some of you engine builder guru's have some ideas what can be wrong with my 1.7liter W code motor i tryed calling brad roberts and jake raby but both didnt answer (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
so heres the dealio.. the case is together. cam is lined up correctly and the crank bearing pins are lined up (far as i can tell i did it 5 times!) everything was going fine and i was starting to torque the case half bolts and checking the rotating assembly. now there is a point in the rotation where it binds (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) flip it back around about 650-700 degrees and it hits the same spot. sitting there with a flash light i couldnt see any of the conrods or counterwights hitting the case or cam. so i undid all the bolts and nuts to see if it was just the case being tweeked but its not. now there is quite a bit of endplay since i dont have a flywheel on the assembly but i really dont think that will cause this problem with the rotating mass. so any suggestions? im going back out too the shop to play with it tommarow thanks... (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
Bleyseng |
Jan 8 2006, 12:19 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
How the motor get so clean? damn, you have been polishing everytime since you had to trial assemble it 5 times? (IMG:http://www.914world.com/bbs2/html/emoticons/WTF.gif) Did you find the shims as it looks like the flywheel is on. Gawd, I ate too much again...two effin parties in one night. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) Oh, DimSum at 11AM at Jade Garden w/ Joe and others. |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:27 PM |
