> 1976 2.0 question, throttle body
jimkelly
post Jan 7 2006, 09:41 PM
Delaware USA
Up untill a few days ago my car was running fine but all of a sudden it started to back fire when I decelerated and starting it became difficult. One thing that has been found is the both the vaccum hoses - light blue and the red to the distributor - both pull vaccum at idle and both lose vaccum when giving the motor some throttle. The red is supposed to have little vaccum at idle and gain vaccum with added throttle - correct? We are thinking that my throttle body has gummed up hole some where but at this moment we don't know how the advance hose nipple is plumbed in the 1976 2.0 throttle body - anyone got any ideas or a detailed drawing of how the advance vaccum flows through it? Thanks, Jim
Rand
post Jan 9 2006, 04:33 PM
Cross Member
I don't mean to beat a dead horse, but this is normal. A port at the air distribution box, below the butterfly, will have maximum vacuum at idle but drop off as the butterfly opens.
The engine is sucking a lot of air. Put a vacuum port in the intake below the butterfly, close the butterfly, and that port will pull a hard vacuum. Open the butterfly and the path of least resistance is the throttle body, not that little port. Vacuum at the port drops.
The hose at the port below the butterfly should go to the distributor retard. So at idle, it retards the timing. Your car does not need the advance side at all.
Sorry for the rabbit trail... I know this doesn't solve your problem, but it seemed like a worthwhile sidetrack. Your problem may be elsewhere.
jimkelly   1976 2.0 question   Jan 7 2006, 09:41 PM
jimkelly   TB   Jan 7 2006, 09:41 PM
Bleyseng   Advance hose from the dizzy is plugged and just la...   Jan 8 2006, 12:15 AM
jimkelly   I could be mixed up but I think we determined that...   Jan 9 2006, 01:36 PM
r_towle   I hate to say this...but check your MPS...pull off...   Jan 9 2006, 02:20 PM
jimkelly   I have a spare MPS - I'll give that a try. Tha...   Jan 9 2006, 02:43 PM
Rand   If you connect a vacuum gauge to that nipple with ...   Jan 9 2006, 02:48 PM
jimkelly   We get a vaccum reading at idle - but it dropps of...   Jan 9 2006, 02:50 PM
Rand   Vacuum at idle but not at throttle = port below bu...   Jan 9 2006, 02:54 PM
Dave_Darling   <...   Jan 9 2006, 02:55 PM
jimkelly   rand - yes - vaccum at idel - it drops off with th...   Jan 9 2006, 03:03 PM
r_towle   the vacuum advance circuit would only need to prod...   Jan 9 2006, 03:06 PM
Rand     Jan 9 2006, 04:33 PMCap'n Krusty   <...   Jan 9 2006, 04:45 PM
jimkelly   Well I changed the mps and things are better but n...   Jan 9 2006, 05:06 PM
jimkelly   pic   Jan 9 2006, 05:07 PM
Rand
  Jan 9 2006, 05:09 PM
jimkelly   Captain wrote opposite Dave - I had to ask despite...   Jan 9 2006, 05:34 PM
Rand   Gotchya... I have read the factory left it UNplug...   Jan 9 2006, 05:39 PM
Bleyseng   <...   Jan 9 2006, 07:31 PM
Bleyseng   pic   Jan 9 2006, 07:37 PM
Dave_Darling   <...   Jan 9 2006, 07:45 PM
Bleyseng   Lookat the 73 2.0 Throttle body with the two ports...   Jan 9 2006, 07:53 PM
jimkelly   Thanks to you guys my baby is feeling a lot better...   Jan 9 2006, 07:56 PM
motorhead   this is interesting! I've had the advance ...   Jan 9 2006, 09:58 PM
jimkelly   My understanding is the adjustment screw on the ec...   Jan 10 2006, 06:15 AM
Bleyseng   ...   Jan 10 2006, 09:38 AM
jimkelly   On my 1976 2.0L I changed my bad 043 mps to a good...   Jan 15 2006, 10:24 AM
Bleyseng   Its because in the first 10 mins of driving the en...   Jan 15 2006, 10:33 AM
jimkelly   geoff, I have a 043 mps that I got from skline an...   Jan 15 2006, 11:05 AM
Bleyseng   If the 043 is bad then its waay to rich so the mot...   Jan 15 2006, 11:49 AM
11 User(s) are reading this topic (11 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 03:25 AM
