no blowing in the car? |
lincoln |
Jan 9 2006, 06:44 PM
Member Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None |
thumbs up to lagunero (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
just got a manual he sent me- pretty cool thing to do by my standards- hell my old mopar aquaintances woulda never did that - makin a lot of sense from stuff now that i have something to actually look at . anyways i cant seem to get the heater blower motor to blow at all, im getting a bit of heat from the heater lever off the motor, and its like a very faint heat is coming up to the windshield vents, not nuff to defog it tho .doesnt seem to be getting power to all the fuses on the fuse board ( gonna be updating that soon ) hooked wipers up to a diff fuse than normal to get them to work but when i try the fan it just starts the fuel pump going any suggestions besides taking it to a shop which i cant afford at the moment?or tearing it down to a tub and completely restoring it heheh - i take pride in being able to keep the old cars on the road for life when possible and so far only 1 died- death by accident that i coulda drove away from if i coulda got the driveline back in the tranny maybe find a small fan that will say plug in the lighter socket just to keep windows clear? |
rhodyguy |
Jan 9 2006, 07:14 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
pull the heater lever on the floor all the way up(open). go under the car and ensure the 2 flapper vales are fully opening, and look at the 2 heating hoses that connect to the openings in the firewall and the valves. the floor lever provides the ground for the aux fan in the engine compartment. look for a little green wire inside the tunnel where the lever is and make sure it's attached. there is a fuse and a relay in the relay plate that provide the power for the fan, p.120 fig 9.21 in your new haynes. on the dash controls, it should read "max defrost: move upper levers left, lower lever right". with the floor lever raised, the valves fully opening, and the dash levers set as discribed, you should feel the air coming out of the defrost outlets on the dash top.
k |
Lo-Fi Version | Time is now: 24th June 2024 - 07:11 AM |
