Welding in cold air, Is it bad? |
VaccaRabite |
Jan 10 2006, 08:10 AM
En Garde! Group: Admin Posts: 13,471 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Over the weekend I bought a welder (Lincoln 140 MIG), helmet, gloves, ans a few sheets of 16 gauge mild steel for practice; and next week I am going to go buy a tank of sheilding gas.
I also bought a book on welding, and it said that welding should be done in a shop where the ambient temps were 90 degres. The author said that 70-80 was ok, but you should not weld when the temperature is cooler then that due to the increased risk of cracking whatever metal you are welding. My initial thought were "Well, there goes my plans for the next couple of weeks," as my garage is unheated and has been between 25-50 degrees for the past months, and will stay there through March. I'd rather not wait till summer to learn how to weld, but I don't want to crack the body of my car - or the longs for that matter. I'd never heard the temperature thing before. Is it considered safe to weld when it is chilly out, or do I need to wait for warmer days? Zach |
John Kelly |
Jan 10 2006, 09:33 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
As Pugbug said, you can weld in very cold temperatures...some folks will pre heat a sheet metal panel slighly with a torch to make the shock of the temperature change a little less. Can't hurt if you have a torch, but if not, don't worry. The rapid change from cold to very hot is less problematic than the rapid change from very hot to cold.
John www.ghiaspecialties.com |
Lo-Fi Version | Time is now: 24th June 2024 - 07:36 AM |
