compression test, how do these #'s look |
toon1 |
Jan 10 2006, 02:25 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Did a compression check last night how so these numbers look to you guy's....
Cyl. # 2 145psi #1 125 #4 130 #3 140 the motor was cold when I did the test.. |
toon1 |
Jan 10 2006, 02:45 PM
I am having problems getting the motor to run right. I had a freind take a listen to it, he thinks there might be a rocker problem. I am going to pull the motor out to adress that and replace the exaust gaskets but he said to do a compression check first. The sound he hears is not major or very loud there is just something little off. He knows more than I so I am taking his advice. What do you all think?
Lo-Fi Version | Time is now: 27th June 2024 - 11:49 PM |
