Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
Well the Shaggy-mobile has been down since just after C-mas. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
It seems to sound like a compression leak to me. The sound started off quite faint but has become louder, kind of a "huffing" sound from the engine. It starts ok, it runs ok, just very anemically (no power), but still seems smooth, both running and idling. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) BTW, I am paying close attention to the following thread- Compression Testing (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) The Shaggster is going to lash the valves this evening as to see what is up, then he will try to operate it again and if it does not operate well, he will then conduct a compression test. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Does that sound right? Anybody want to register any experienced or educated guesses as to this latest malady? The engine was out of the car recently, and the valves we adjusted by the Shaggy MANY times. Wish the lad luck, I am concerned he is gonna need it...... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) John P.S. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Sounds like a blown "Head gasket" to me... The 1.7 seldom does this, but it can happen.
You can easily find it with a LEAKDOWN TEST, not a compression test. The leakdown test wil clearly illustrate where the air is leaking from and it really helps with narrowing the possible causes of the issue a lot. Valve adjustments are not cure alls.... A blown head gasket would never be effected by a valve adjustment. You'll soon see why we remove the head gaskets. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:07 AM |
