Voltometer Question, experiment only shows 8 volts, why? |
DougC |
Jan 11 2006, 10:34 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Hey guys I have a VDO voltometer that i will be installing in my 914.. well, last night I thought I'd make sure it worked before installing it and it would only show 8 volts. The "experiment" was that I just held the thing in my hand and attached a wire from the + side to the + side of my (new-ish) Optima battery, and a wire from the - on the voltometer to the - on my battery. The needle would just bearly bounce off it's resting place to about 8 volts. Did I test it right? Could my car actually be getting me around day-in/day-out on only 8 volts? The Optima is basically new, only had it for a few months but hit the starter a whole bunch trying to get my car to start when I installed my engine. Been driving the car daily for about 2 weeks now.
Doug C |
914GT |
Jan 11 2006, 10:52 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Your battery is probably OK and about 12V (measured with engine, lights, etc. off) if it's been starting the past 2 weeks. If the engine cranks for a long time and doesn't start that's usually a fuel or ignition problem. Chances are the voltmeter is out of calibration or defective. The only way to really check it is to get a digital voltmeter and compare its reading at the same measurement points to your VDO meter.
Lo-Fi Version | Time is now: 22nd June 2024 - 09:35 PM |
