racergreg |
Member ![]() ![]() Group: Members Posts: 91 Joined: 4-April 05 From: Fullerton, CA Member No.: 3,869 ![]() |
Ok, the 6 is bolted in (a very cool CIS 2.4). Everything is working out great, I have the oil plumbing going in fine. NOW, the question is how to connect the throttle cable. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
The stock connection (one of those little balls mounted on a bell crank) is carefully wedged in between the velocity stacks and the CIS pump unit, only a couple of inches from the rear sheet metal. In the 914, the ball needs to be pulled toward the BACK of the car. From what I can tell, the cable will need to be mounted behind the sheet metal, and then go through a hole to the linkage. Can anyone share some ideas or pictures? I would really appreciate it. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,642 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Greg,
here is my version. close to stock -6 except the stock version screwed into the tranny a couple of inches forward of mine. most people make a 3rd version that bolts onto the tranny a little forward of mine too. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:42 PM |
