914-6 throttle cable, need help on my conversion |
racergreg |
Jan 11 2006, 04:02 PM
Member Group: Members Posts: 91 Joined: 4-April 05 From: Fullerton, CA Member No.: 3,869 |
Ok, the 6 is bolted in (a very cool CIS 2.4). Everything is working out great, I have the oil plumbing going in fine. NOW, the question is how to connect the throttle cable. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
The stock connection (one of those little balls mounted on a bell crank) is carefully wedged in between the velocity stacks and the CIS pump unit, only a couple of inches from the rear sheet metal. In the 914, the ball needs to be pulled toward the BACK of the car. From what I can tell, the cable will need to be mounted behind the sheet metal, and then go through a hole to the linkage. Can anyone share some ideas or pictures? I would really appreciate it. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
john rogers |
Jan 11 2006, 04:23 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
On my race car we did not use the stock bellcrank and linkage, but used a 4 cylinder cable and made a small aluminum bracket at the back of the engine and the cable routes under the engine and in the rear sheetmetal. The cable pulls towards the rar of the car with mine. A lot less moving parts and those ball joints that tend to pop loose at times.
Lo-Fi Version | Time is now: 24th September 2024 - 12:53 PM |
