914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Guys:
Tonight I ran the 5/16" steel lines (from Summit) through the tranny tunnel. They went in pretty easy, but getting them throught the front grommet was a bitch. So, now I have about 2 feet of steel line coming out of the rear firewall. How do it get to the engine compartment? I don't think I can/should try to bend the steel lines up into the engine compartment, although I'd like too, I think I'd kink the lines. This stuff is flexible, but not THAT flexible. What have you guys that used steel lines done? I've heard mention of using flexible line to make the right turn and up through to the engine compartment. What kind should I use? Where can get it? I thought about re-using a section of the plastic line that I took out of the tunnel, but how would I connect it to the steel line, since they're both the same size? A small connecting 8mm hose with a clamp at each end? I'd be concerned about putting a clamp on the plastic line, but maybe it'd be OK. Any thoughts/ideas are appreciated!! Thanks, Andy... |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
When I make fuel lines from stainless tube I bend them 90 at the firewall and run it along the bottom of the firewall to where the fuel pump goes. Then I make another section to go up through the engine shelf and join them with a short piece of rubber fuel line.
I have a set of old plastic lines that I copy the shape of before fitting them into the car. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:19 PM |
