> V8 Conversion Completed, 1975 1.8L to Chevy 283 - Added Dyno Test Pg. 1
nick mironov
post Jan 15 2006, 12:58 PM
nickm
My conversion took approximately 5 months of work to get the engine in and get the car on the road. Another 18 months for further work and improvements. Thanks very much to the 914 Club Forum and those who posted their conversion information and to those who responded to my questions, and special thanks to the club members who attended the V8 conversion meeting in Pleasanton in September 05 and shared their valuable knowledge with me.
If anyone is interested in seeing the car, I live in the Richmond District of San Francisco.
Project Specs:
1975 1.8L 914
Renegade conversion kit
Chevy 283
Vortec heads
Compcam 260H
New cam bearings
0.060 cylinder overbore
New rods and pistons (9.5:1 compression ratio)
New main and rod bearings
Replaced all gaskets and freeze plugs
New high volume oil pump
MSD Billet HEI distributor
Holley 4 barrel carburetor
Treated miscl rust with OSPHO and Por 15 paint
Herculiner truck bed liner in front and engine compartments
911 19mm master brake cylinder upgrade
BMW 320i front caliper upgrade to start with,
M-caliper upgrade using hubs by Mueller
Stainless steel flex brake hose upgrade
Replaced rear brake proportioning valve with TEE.
Rebuilt rear brake calipers
Pedal cluster bushings upgrade to brass (from existing plastic)
Replaced transmission shifter bushings
Replaced transmission seals
Weltmeister short-shifter
WEVO transmission mounts
9” Kevlar clutch
New Bilstein rear shocks and bellows/boots.
Electric fuel pump – Carter CRT-P4070 5 psi, 72 gph
New / custom throttle cable
HP mini-starter
2-gauge wire to starter
Ron Davis Radiator with two 13”diameter SPAL fans (Renegade set-up)
Renegade bypass thermostat system
VDO Water temperature gauge
VDO Oil pressure gauge
VDO Oil temperature gauge (original)
Tachometer upgrade by bigmarkdesign
Oil Cooler
Center console
Rear trunk strut conversion kit – Camp 914
Magnaflow dual-in dual-out muffler
Body work and re-paint
Power mirrors from Honda del Sol
Rear wing from Toyota MR-2
Interior seat and backpad kits by Autos International
Carpets by Morph
Towbar for flat towing with integral wiring harness
16" 4-lug Superlight wheels from Pack Racing Products
BF Goodrich G-Force Sport 205/55/16.
The dyno tests were done this 8/24/2008 at the Thunderhill dyno. At max rpm of about 6,250 the dynamometer showed a speed of 153 mph. On the track we got it up to about 125 mph. However, it threw a water pump belt a couple of times. I think that there is too much flex in the Renegade water pump mount, so I need to reinforce it.
At rear wheels: 263 ft-lb torque, 241 hp.
Engine: Assuming a 15% loss through the transmission, the engine would have about: 302 ft-lb torque, 277 hp.
Maybe more if the test was done on a motor dyno stand without water pump, alternator, and muffler.
Without air filter:
With and without air filter:
nick mironov
post Jan 15 2006, 01:00 PM
nickm
Started on the radiator first:
nick mironov   V8 Conversion Completed   Jan 15 2006, 12:58 PM
nick mironov   I bought the car in June 05, ordered and collected...   Jan 15 2006, 12:59 PM
nick mironov   Started on the radiator first:   Jan 15 2006, 01:00 PM
nick mironov   Cut the front and isntalled the radiator and shrou...   Jan 15 2006, 01:01 PM
neo914-6   Nick, Great job, another Bay Area conversion...   Jan 15 2006, 01:02 PM
nick mironov   Another view of the radiator:   Jan 15 2006, 01:03 PM
nick mironov   Cut the bumper:   Jan 15 2006, 01:03 PM
nick mironov   Finished front:   Jan 15 2006, 01:04 PM
nick mironov   Removed gas tank and cleaned up the rust within th...   Jan 15 2006, 01:05 PM
nick mironov   Cleaned out and painted the gas tank:   Jan 15 2006, 01:06 PM
nick mironov   Cleaned out rust from front compartment, painted ...   Jan 15 2006, 01:07 PM
nick mironov   At this time, I have not committed to cutting the ...   Jan 15 2006, 01:10 PM
nick mironov   Engine compartment was also cleaned out of rust,...   Jan 15 2006, 01:12 PM
nick mironov   Primer over POR 15 paint - ready for Heculiner:   Jan 15 2006, 01:13 PM
nick mironov   Trunk was de-rusted and treated with POR 15 paint...   Jan 15 2006, 01:15 PM
nick mironov   Engine rebuild:   Jan 15 2006, 01:16 PM
nick mironov   Mostly compete engine:   Jan 15 2006, 01:17 PM
nick mironov   Transaxle was thoroughly cleaned. All of it was ...   Jan 15 2006, 01:19 PM
nick mironov   Engine amd transaxle are mated and ready to be in...   Jan 15 2006, 01:20 PM
nick mironov   Going in:   Jan 15 2006, 01:21 PM
nick mironov   Going in... I actually did the install by myself...   Jan 15 2006, 01:23 PM
nick mironov   Installed. Right side before exhaust installation...   Jan 15 2006, 01:26 PM
nick mironov   Installed. Left side after exhaut installation. No...   Jan 15 2006, 01:28 PM
Boxer_Twins   Installed. Left side after exhaut installation. N...   Jul 20 2008, 07:28 AM
michaelt55   [quote name='nick mironov' post='580102' date='Ja...   Jul 31 2008, 06:58 PM
nick mironov   Rear view:   Jan 15 2006, 01:28 PM
nick mironov   Coolant accessories:   Jan 15 2006, 01:29 PM
nick mironov   Carter electric fuel pump (noisy). The heater tub...   Jan 15 2006, 01:31 PM
nick mironov   Rebuilt pedal cluster:   Jan 15 2006, 01:32 PM
nick mironov   Custom throttle cable. I drilled and tapped the ...   Jan 15 2006, 01:36 PM
nick mironov   Throttle cable setup at the carburetor:   Jan 15 2006, 01:38 PM
dmenche914   Nice!!! So the radiator air exit is t...   Jan 15 2006, 01:38 PM
nick mironov   Muffler - sure is loud without one:   Jan 15 2006, 01:39 PM
nick mironov   Magnaflow #12468   Jan 15 2006, 01:39 PM
dmenche914   I like that muffler, i have a flowmaster mounted s...   Jan 15 2006, 01:43 PM
Crazyhippy   Very nicely done. My only concerns are: 1: The cu...   Jan 15 2006, 02:22 PM
r_towle   Awesome job, really nice work. Did you modify the...   Jan 15 2006, 02:35 PM
Dr. Roger   you can reduce the sound made by the fuel pump by ...   Jan 15 2006, 02:46 PM
nick mironov   As I mentioned, I have three hoods that I will be...   Jan 15 2006, 03:34 PM
messix   fuel pump: it looks like the pump to bracket is is...   Jan 15 2006, 03:49 PM
Andyrew   Hood venting will work fine only if you put a litt...   Jan 15 2006, 03:56 PM
dmenche914   Might be worth a try taping some ribbons on the ho...   Jan 15 2006, 04:16 PM
Andyrew   Nick, I'd leave the fuel pump alone... You wan...   Jan 15 2006, 04:43 PM
twistedstang   Nice looking conversion. Looks really clean <...   Jan 16 2006, 12:56 PM
jd74914   Andy, I have no idea, the car isn't mine, but ...   Jan 16 2006, 01:26 PM
jd74914   And the bonding, kinda looks like this spoiler, m...   Jan 16 2006, 01:27 PM
nick mironov   Upgraded the BMW 320i brakes to M-Calipers using M...   May 4 2007, 08:18 PM
nick mironov   The hood vent experiment worked, but the heat flow...   May 4 2007, 08:21 PM
nick mironov   Added an oil cooler to the engine. I mounted it ho...   May 4 2007, 08:22 PM
nick mironov   I changed the Renegade provided rubber hoses for s...   May 4 2007, 08:24 PM
nick mironov   After lots of body work, and a spray-can prime to ...   May 4 2007, 08:29 PM
nick mironov   Back from the painter and finally re-assembled: Pa...   May 4 2007, 08:30 PM
6freak   Back from the painter and finally re-assembled: P...   Aug 29 2008, 09:26 AM
jimkelly   shit - beautiful paint : ) I took my car today fo...   May 4 2007, 09:02 PM
DSM   I'd imagine that short stroke 283 twist up pre...   May 4 2007, 09:23 PM
wbergtho   Looks like another nicely done conversion. Good sh...   May 4 2007, 09:23 PM
Crazyhippy   The front bumper inlet is perfectly fine. I reall...   May 4 2007, 10:11 PM
Dr Evil   Wow, man. Just WOW. Very nice! :thumbsup:   May 4 2007, 10:30 PM
Gint   Found it.... :ttiwwp: That looks great Nick. Mo...   May 9 2007, 08:25 PM
nick mironov   There will be more pictures in a few weeks. I will...   May 10 2007, 12:48 PM
Justinp71   Looks nice... Maybe a 911 front suspension clip wo...   May 10 2007, 01:38 PM
Root_Werks   :trophy: Nice! Can't believe I haven...   Aug 1 2008, 09:31 AM
Wanna9146   I know it's too late, but my Pantera has two (...   Aug 1 2008, 10:09 AM
jt914-6   What he was talking about with the heat getting in...   Aug 1 2008, 12:05 PM
Wanna9146   What he was talking about with the heat getting i...   Aug 1 2008, 12:19 PM
jt914-6   As far as I know, fresh air always comes in from t...   Aug 1 2008, 04:17 PM
3d914   IIRC you also have to close the two side vents, as...   Aug 1 2008, 05:49 PM
nick mironov   See dyno tests added to page 1. Nick   Aug 28 2008, 05:34 PM
computers4kids   See dyno tests added to page 1. Nick Thanks fo...   Aug 29 2008, 08:29 AM
So.Cal.914   I googled So Cal Dyno testing...http://www.socaldi...   Aug 29 2008, 09:22 AM
fiacra   Looks like this car is now up for sale on SF Craig...   Mar 28 2024, 05:16 PM
burton73   Looks like this car is now up for sale on SF Crai...   Mar 28 2024, 06:58 PM
Root_Werks   Nice to see all these years later the 914 is still...   Mar 29 2024, 10:45 AM
Steve   Nice car!! Good price if their is no body...   Mar 29 2024, 11:33 AM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 10:20 PM
