michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
In the process of restoring my 914/6, I want to have vented rear rotors, mostly because I'm going to have a big engine, but also because I think it's kinda cool.
The stash of parts I bought from Jon Lowe contained some rebuilt original 914/6 rear calipers. It also contained some good condition 911 front calipers "A" calipers I think: 3 inch bolt spacing, steel, and with a spacer. They had 48 mm pistons. To build rear calipers that have a spacer, there is one recipe that uses the spacers from the rear of 911 mid-year calipers, as well as other hardware. Those spacers are 10 mm. I don,t have such calipers and initial attempts at getting some were unfruitlful. So, I took the spacers from the front calipers that I have, but they're 7.5 mm thick. Attached image(s) ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Yeah Michel!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Yeah Brian!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) You probably don't have the pins, they have to be custom made with the one large pin diameter (one pair may work). Spacers and hardware would be the ticket, also, the 911 pad springs will also be needed. Paul, Those are the exact same caliper with one difference, the bleeders are 180 degrees oppositie the 914-6/GT caliper. |
