OT: 230v welder wiring, using a dryer circuit |
bondo |
Mar 23 2005, 04:23 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I just got a millermatic 175 welder. 230v, 19.5 amps. I'm going to make an extension cord for it and was wondering what guage wire I should use. Is 12ga enough? (going about 30 feet, just enough to get all the way around the garage, and into the driveway a bit)
Also, the dryer outlet is neutral grounded. Should I use it as is or add a second outlet with a real ground? |
914GT |
Jan 16 2006, 12:17 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I know my local home depot has 4-conductor #6 flexible cord. If they have 3 conductor too then that's all you need since it's just two hots and ground on the welder. Wire one end directly into the welder and the other to a dryer plug and you're done.
Lo-Fi Version | Time is now: 20th October 2024 - 02:45 AM |
