michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
In the process of restoring my 914/6, I want to have vented rear rotors, mostly because I'm going to have a big engine, but also because I think it's kinda cool.
The stash of parts I bought from Jon Lowe contained some rebuilt original 914/6 rear calipers. It also contained some good condition 911 front calipers "A" calipers I think: 3 inch bolt spacing, steel, and with a spacer. They had 48 mm pistons. To build rear calipers that have a spacer, there is one recipe that uses the spacers from the rear of 911 mid-year calipers, as well as other hardware. Those spacers are 10 mm. I don,t have such calipers and initial attempts at getting some were unfruitlful. So, I took the spacers from the front calipers that I have, but they're 7.5 mm thick. Attached image(s) ![]() |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Turn the 911 rear rotor down to 286mm from 290mm.
I know it is not much but the extra weight and unused surface is detrimental. Also provides the needed clearance. |
