Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
well. my carb'd 2.0 has about 6500-7000 miles on it since rebuilt last summer. i drive it hard and such, but for the most part it has been good. here's my pproblem- after driving like 45 min - 1hr at like 75 mph, if the car's idle drops below a 1000 rpms at a light, the oil pressure idiot light will flicker and then come hard on- so i heel toe it to stay above 1000 rpms (hot idle carb issue- working on it!!) here is what i think is happening. the stock oil pump sucks. also, i think the oil is getting too hot and thinning out so the pump has a hard time pumping.....
external oil cooler? HD oil pump? what do i do? btw- fresh oil change- proper level, 20w-50 |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I'm having the same problems plus a leak on a 5K engine that I AX fairly hard. I'm at about 5 lbs at 220 degrees. I need a new oil pump asap.
Lo-Fi Version | Time is now: 4th July 2024 - 12:59 PM |
