> Detailed pics of RX7 cooler, For GT style front mounting
michel richard
post Jan 23 2006, 07:39 PM
The current thought is to install a modified Mazda RX7 cooler in the front of my GT style conversion.
I bought a cooler off Ebay, for 10 bucks and it showed up on my doorstep today. I must say I'm quite impressed with the quality of the part. It's welded aluminum and the craftsmanship appears to be on par with German Behr parts.
I shot a bunch of pictures and thought they might be of interest to some on the list.
Here's an overall view:
Rotary'14
post Jan 24 2006, 09:42 PM
I've now seen 3 different variations of that cooler. Mine has the exits out the side. That bottom hole is plugged.
I took some threaded aluminum rod and welded them to an aluminum plate which I welded across the top attached to both ends. The rods go through the holes in the factory GT shroud. Looks like a factory cooler.
This is due to the different generations of RX-7 (1979-1985,1986-1992, 1993-1995). Early oil coolers have inlet and outlet facing the same direction, not one in the side and one on the bottom. Despite the different locations, I don't think it adversely effects oil flow.
I think the mazda oil cooler is a very well designed cooler, because the rotary engine rejects about 1/3 of it's heat via the oil cooler, so the unit must be robust.
-Rob
michel richard   Detailed pics of RX7 cooler   Jan 23 2006, 07:39 PM
michel richard   The business end:   Jan 23 2006, 07:40 PM
michel richard   the thickness   Jan 23 2006, 07:40 PM
michel richard   The height:   Jan 23 2006, 07:41 PM
michel richard   There is a built-in pressure relief valve that uns...   Jan 23 2006, 07:47 PM
shadygrady   That's what I have in my car. The motor is a ...   Jan 24 2006, 09:19 PM
Eric_Shea   I've now seen 3 different variations of that c...   Jan 24 2006, 09:31 PM
Rotary'14     Jan 24 2006, 09:42 PMmichel richard   In the process of transforming the cooler, I cut o...   Jan 31 2006, 08:12 PM
michel richard   Not absolutely sure how this is going to work out,...   Mar 10 2006, 07:55 PM
michel richard   another view   Mar 10 2006, 07:55 PM
michel richard   The fitting (I'll use two of them) is threaded...   Mar 10 2006, 07:57 PM
michel richard   What remains is to pressure test it, take it to a ...   Mar 10 2006, 08:03 PM
Aaron Cox   ive also heard that some of the rx7 coolers had a ...   Mar 10 2006, 08:31 PM
michel richard   I think I remember seeing a picture of the removab...   Mar 10 2006, 08:35 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 9th January 2025 - 05:47 AM
