swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
KB - 96mm pistons and stock overbored steel barrels. I'm getting ready to ring the pistons and check/set the gap. I believe the gap should be about .006", but can't remember and can't perform a search for some reason (some virus has dissed me).
I placed a ring in the top of the barrel and the gap was around .021". That's a bit over .006". Am I measuring it the right way? I measured my pistons and yes they are 96mm. Of course I 'll second guess myself and check again. Thanks dudes. Wow, post #100! I'm getting up there! |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
You need to check the rings about 10mm down from the top (you may know this already) I also check them about midway down in the bore. .006 is fine for the street (other will chime in if it isnt).
I'm happy that your checking them.. B |
Lo-Fi Version | Time is now: 7th July 2024 - 07:39 AM |
