V8 radiator outlets, alternative to cutting wheelhouse? |
914ltd |
Jan 24 2006, 11:01 AM
Member Group: Members Posts: 243 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
Hi Guys, A couple years ago we took a 914/Chev back to stock for a customer. I then decided to build a 283 powered car for myself. I would like to avoid the huge cutouts in the wheelhouse. has anyone mounted a fan on the trunk floor, possibly with the 2 fans already on the radiator? This would be great for an already AC cut trunk floor. I'd appreciate your input. Thanks! Brad
914 Limited Inc. Brad Mayeur 1162 N. Byerly Hills Dr. East Peoria, IL. 61611 309-694-1797 Fax 309-698-2203 P914ltd@yahoo.com |
bondo |
Jan 25 2006, 12:18 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
The strength of that area comes from the compound curve.. There's a big enough flatish spot that probably doesn't add much strength, and if you cut out both sides it should be enough area for your average V8. That's what I did, we'll see how it works. If you are still worried you can weld in expanded mesh. That will bring back most of the strength but still allow air flow.
Lo-Fi Version | Time is now: 28th September 2024 - 03:41 PM |
