rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
They guy at the local auto body shop said that metal ready wasn't necessary (probably because he was out of the stuff) before using POR15 as long as I did a good job of grinding all of the rust out.
This doesn't sound correct as I'll never be able to grind and clean up ALL of the rust particles... However, I've seen the instructions for the Metal Ready stuff, and it sounds like a big mess. Is there another product that's less messier that will do the same thing (assuming I need it)? Rubbing alcohol? (at least that stuff will evaporate on it's own). Also, I've got areas where I won't be able to wash the metal ready stuff out of if I apply it (center tunnel comes to mind). I can't just spray Metal Ready in there because it's an acid and eventually will destroy the metal- I have to be able to wash the stuff out. So do I just try and coat with POR15 using some sort of 'rag-on-a-pole' method?? New pics of the longs, rust etc: http://www.914world.com/bbs2/index.php?act=...&hl=metal+ready Since I have a couple of small areas to weld later, can I grind of the POR15 easily (or easily enough) when the time comes to weld those areas? (ie: holes due to rust) |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
There are some who would say the opposite: use Metal Ready (or equivalent) and DON'T use POR-15.
If you use anything with phosphoric acid (Metal Ready, Ospho, Navel Jelly, etc) in it, you're converting the rust from iron oxide to iron phosphate, which won't rust any furthur, and the phosphate ions occupy all of the space the oxygen ions are trying to attach themselves to. POR-15, et al, will "seal" the metal so more oxygen atoms can't get to the iron atoms, so rust is stopped. My take is to use both. Metal Ready over rusty metal will halt the rust that's forming now, and it gives you a better surface for the POR to stick to. It also etches the metal that's not rusty, which also increases the chances of the POR sticking to that. The Metal Ready doesn't do much to protect steel that's not already rusted, which the POR will do. Ospho only converts, it doesn't etch. I think Jasco will do both. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:17 AM |
