ynotdd |
Member ![]() ![]() Group: Members Posts: 156 Joined: 13-January 03 From: plainview, NY Member No.: 140 ![]() |
I use my 914 for autocross mainly and have never had a heat problem at all. I want to do some DE's.I have an oil cooler kit( cooler, fan,thermo, filter relocator) that puts the cooler under the rear trunk that is not installed yet. My question is will this be ok for DE? and does anyone have pic's on how this looks installed?
Racer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region ![]() |
You didn't mention if the car is modified or not.. is it?
My guess is that with the use of a quality motor oil, and this being one of your first DE's, I wouldn't worry about a cooler just yet. Also if your running LRP in the fall, it doesn't usually get that hot, which will help you. Like someone said before, make sure your gauge works correctly and just watch the temp closely. |
Lo-Fi Version | Time is now: 4th July 2024 - 11:57 AM |
