rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
They guy at the local auto body shop said that metal ready wasn't necessary (probably because he was out of the stuff) before using POR15 as long as I did a good job of grinding all of the rust out.
This doesn't sound correct as I'll never be able to grind and clean up ALL of the rust particles... However, I've seen the instructions for the Metal Ready stuff, and it sounds like a big mess. Is there another product that's less messier that will do the same thing (assuming I need it)? Rubbing alcohol? (at least that stuff will evaporate on it's own). Also, I've got areas where I won't be able to wash the metal ready stuff out of if I apply it (center tunnel comes to mind). I can't just spray Metal Ready in there because it's an acid and eventually will destroy the metal- I have to be able to wash the stuff out. So do I just try and coat with POR15 using some sort of 'rag-on-a-pole' method?? New pics of the longs, rust etc: http://www.914world.com/bbs2/index.php?act=...&hl=metal+ready Since I have a couple of small areas to weld later, can I grind of the POR15 easily (or easily enough) when the time comes to weld those areas? (ie: holes due to rust) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
I don't see the point of trying to spray Metal Ready inside the longs. I guess we'll get different opinions on this, but... Metal Ready is for etching. The inside of your longs don't need that. If you're gonna spray something in there, use something that will encapsulate the rust (kill it) and stop it from spreading.... Such as Hammerite or POR 15.
Lo-Fi Version | Time is now: 26th June 2024 - 07:01 AM |
