Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
I started removing all the nasty road grime and undercoating from the wheel wells and under the car this weekend with a hand grinder fitted with a coarse wire bit. It will take quite a while to cover the entire car, but it is worth it IMHO. I also removed the sound insulation material from the engine bay and started grinding that area also.
My Question: -What do you all recommend on using to repaint both the underbody of the car and the engine bay? I was thinking on POR-15 for the underbody and wheel wells, will this look good under there and hold up to the elements? What about the engine compartment? Will POR-15 withstand the heat? I would like to paint the engine bay possibly red, what paint is good for this? -Britain (IMG:http://www.britainsmith.com/Porsche/912Misc/images/125_2593_JPG.jpg) |
kafermeister |
Senior Member ![]() ![]() ![]() Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 ![]() |
QUOTE(Britain Smith @ Sep 2 2003, 01:06 PM) I was thinking on POR-15 for the underbody and wheel wells, will this look good under there and hold up to the elements? What about the engine compartment? Will POR-15 withstand the heat? IIRC, POR-15 will withstand almost anything...eccpt UV. It needs a top coat to protect it from the sun. Me thinks that for work *under* the car, a sand blaster wouldn't be such a bad idea. Try using oven cleaner on the undercoating....then the sand blaster to remove rust/paint. Rick |
Lo-Fi Version | Time is now: 4th July 2024 - 11:55 AM |
