tyler |
Member ![]() ![]() Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 ![]() |
I had a joint come apart with, thankfully, no damage. It looked like the 4 capscrews just loosened up and separated the joint. Before I replace the bent cap screws and put it back together, I thought I'd ask for the following info from the experts:
1. What should they be torqued to? 2. Should they have lockwashers? 3. How about installing a lockwire thru the 4? Thanks |
lincoln |
Member ![]() ![]() Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None ![]() |
drivers side? thats the one i had work itself loose, what i did - that so FAR has worked- is i hit them with locktight red and added regular lockwashers - replacement bolts came off a bug trans so were slightly longer anyways- then torqued the hell out of them- just to be on the safe side tho im carrying an allen wrench in my pocket and i check them everytime i get ready to go somewhere- only takes a minute to check- takes hours to fix if they come out again
IF they come loose again , i will be going with an ARP grade 8 or better thru bolt and lockwashers and locknuts and possibly wire |
Lo-Fi Version | Time is now: 29th June 2024 - 01:45 AM |
