John2kx |
Senior Member ![]() ![]() ![]() Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 ![]() |
I'm running 5 lug Fuchs on my 914 and have had two valve stem failures since wheels were installed 6 months ago. Both failures have been on the front and on opposite sides. Failures both seem to be from shank section of stem and have shown up as slow leaks luckily and not total failures while at speed.
I use the best tire shop in town for mounting and balance and see many high end cars worked on there. Is my tire guy missing something? The stems used are a rubber material. I seem to remember seeing some type of stem support back in the 70's. Are these required? My car does see 100 mph on a regular basis and 130 or so on occasion if this makes a difference. John |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
yeah.. I forgot you had 16's.. only the 14's and 15's had the tubes (as you found out). I wonder why you are having this problem. Another thought: The tire guy's use a valve stem "puller" to install them correctly... well.. they stand a chance of scuffing the rim if they use this tool... so he may be shying away from installing them correctly with the tool. Ask him.
B |
Lo-Fi Version | Time is now: 7th July 2024 - 05:53 AM |
