swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
KB - 96mm pistons and stock overbored steel barrels. I'm getting ready to ring the pistons and check/set the gap. I believe the gap should be about .006", but can't remember and can't perform a search for some reason (some virus has dissed me).
I placed a ring in the top of the barrel and the gap was around .021". That's a bit over .006". Am I measuring it the right way? I measured my pistons and yes they are 96mm. Of course I 'll second guess myself and check again. Thanks dudes. Wow, post #100! I'm getting up there! |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
The measurement at the piston skirt is where you compare with the cylinder bore. The top of the piston has much more clearance.
In order to get an accurate cylinder bore measurement you need a better bore gauge. It is very difficult to get a true reading with a "snap" gauge. |
Lo-Fi Version | Time is now: 7th July 2024 - 07:03 AM |
