machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Any clues where this oil can be coming from? Looks like a spray or sporadic leak under cornering maybe. In right rear area of compartment.
Also, new plugs all look slightly black with little or no oil. I guess that is good? And I pulled one of the wires right off the connector. Can I just push it back on or is it toast? They were brand new bosch wires. Thanks, david (IMG:style_emoticons/default/confused24.gif) Attached image(s) ![]() |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Black plugs means you are running rich which is better than lean. What year or numbers ECU and MPS? Has the MPS adjusted? On a dyno? Does the MPS hold a 15hg vacuum for 5 minutes? Could be leaking
Geoff |
Lo-Fi Version | Time is now: 7th July 2024 - 06:37 AM |
